I tried logging the duty cycles.. but not sure if I'm doing it right. "Fuel Control actuator duty cycle" is what I logged and the highest number I saw on the chart was 41.1. I'm gonna go load the tune now though with the higher maximum duty cycle though and see how my fuel amounts react to that.
I think I'm up to Round 4 starting back from stock... I'll get this yet!
Best tune so far.. Upped the main injection pulse width, the whole table by 20%. Disabled post injection. Added 6 degrees to all Main Injection timing tables and smoothened them out. Smoothened Rail Pressure Table. Disabled wastegate. 35 PSI of poost and max EGTs I saw were 1300 but was scared to go fast cuz I got death wobble again earlier today. I would estimate to be about a 60 hp tune.
I also tried taking out pilot injection after 2400 RPMs, but I must have done something wrong because it right aways idled at 1000 RPMs and then when it started going down it was getting pretty rough so I just shut it off. Might not even mess with it.
How did you remove pilot?? Quantity or pulse??
Or timing??
~Les
Quantity, just like I was told to on the post injection which has worked just fine. Is the pilot different? Is there more that has to be modified? I totally thought I didn't change anything before 2400 which is why it seems weird why it was idling the way it was.
On thing to consider also, I like leaving the pulse stock under 30mm3 and 80mpa... For starters at least
Yeah maybe that would help with the way it idles I'm guessing..
Yeah, try increasing your fuel from 70mm3 and 120mpa on up and just Smoothen down a few times to say 40mm3. This will keep your idle correct
1 Attachment(s)
here is a screen shot of my pilot...works well for me.
~LesAttachment 11077
Thanks, I might try that.. just not even sure what it helps besides that I feel like trying stuff...
Did you change anything on the Main injection for it to run good?
