Runaway highlight setup pic
BAM!!! Thanks works great!!!
~Les
Thank you 06redram.
Just trying add my little 2 cents of change. lol
i am having problems when reviewing a log in tune tool. problem is the log doesent play from start to finish when watching it in tune tool. it goes to random frames and stops. sometimes its frame 300, sometimes its 800. when i watch it is scan tool its just fine, only when scan tool is playing behind tune tool screen does this happen, any ideas.
I can't really pin point anything exactly. But I do know sometimes reviewing my logs when I want to play or move frame by frame it's gets screwed up and jumps frames as you described. To remedy it, all I do is click "stop" in the log (it will restart to beginning of log) and then resume whatever command I was wanting to do and all is fine.
On a different topic, I noticed when viewing some tables some parameters didn't match up to the appropriate values in tune tool. It was not a problem though. Somehow the parameter I data logged switched to either Imperial or Metric units (whichever was opposite of tune tool) and of course would not give correct info. All I had to do was: in the log under PID's tap, right click the PID and make sure it was viewing in the appropriate units. The all was well. Just trying to keep an issue from arising.
For example, when viewing pulse width table in tune tool, if fuel pressure is in the maxed out column (180mpa or so) your PID in the log is probably in Imperial units (psi, so you can see where it'll always read maxed out in tune tool all the time since the lowest itll see is 7k psi or so, way above 180.)
Fubar what is wrong with D0502 no movement in reading data log
Make sure you logged mm3's and your fuel pressure PID in Scan Tool is in metric units. Right click on PID and it will have a check mark on imperial or metric. For some reason they'll just change once in a while, other people are experiencing the same thing with the scan tool changing units without them knowing so.
