Are they out yet?
I would bet it's using the E39 ECM, so yes it'll be EFILive friendly.
Yes!!! :w00t::coool:
Well the Verano T has the same general engine (LHU) as in the Solstice/SKY Turbo models (LNF) and the ECU is Bosch for the Solstice/SKY.
But EFILive supports it in the Regal GS that uses the LHU so does that mean that it's supported?
Grrrrr... I was planning on purchasing a new car this weekend.. Will it be a Cruze, Regal GS, or 328i? Now we can consider the Verano T... grrrr... decisions decisions..
Bosch ECM's are history with the GM SIDI engines now, everything has switched to the E39.
I don't know what the Verano T looks like, but if I had all those as an option I'd probably take the Regal. The Cruze is a good car, but it's a little bit too small.
The Verano is a Cruze, with some nice Buick touches and big engines.
You guys have all the choices :bawl:
I am having a strange issue with logging the Cruze. When I try to log any other PIDe than the same ones I always have in my shared logs, I get an error. This includes even validated E78 PIDs. If I add just one new parameter (for example, Current Gear or Octane Scaler) it won't work at all.
Keep your total number PID channels below 24 and it should be fine (try removing 1 or 2 PIDs and try it again). I have not asked Ross about this, but it seems like we are limited to 23-24 PIDs max, even when using Dynamic mode.
Are you using a laptop or the V2?
My laptop has never even been in the Cruze, I just use the V2 (for logging and flashing). The V2 will log more PID's and faster than V7.5 pass through.
On the V2 I have 42 channels on the ECM and 22 on the TCM, but I think I'm going to drop the TCM from my logs for some extra speed.
