Ok, stickied and added to Cellected stuff thread.
No you dont need innovate log works to hook up serial to V2.
Thanks, about to purchase one of these and jump into tuning.
The DB9 cable that comes with the LC-2 does not need to be modified. All I had to do was swap 2 wires on the LC-2 plug. Logworks still works fine. One thing I haven't confirmed is if the free air cal from the V2 actually works on the LC-2 or if it will need to be done in logworks. I know it definitely worked on the LC-1.
Free Air Cal should be able to be done form V2.
Received a LC-2. Decided to ohm out the unmolested cables with null modem.
Haven't hooked it up to test yet but this is how it laid out.
Note Black and Blue are common.
Attachment 16378
Pic is a modified one that I found here.
http://forum.efilive.com/showthread....l=1#post121837
Would like to try and find the 4 wire connector that Innovate uses to make up a custom length cable without a DB9 or null modem.
Plug had HRB written on it so did some searching.
Found P3025-2x2-B-H to be the part number.
http://www.hrb-dg.com/upload/1381732172.pdf
Chinese part that could only be bought in bulk so did some more searching. Came up with this.
Molex receptacle 43025 and 43030 terminal.
http://www.molex.com/pdm_docs/ps/PS-43045.pdf
Mouser has these. p# 43025-0400 receptacle and 43030-0012 terminal.
http://www.mouser.com/Search/Product...538-43025-0400
http://www.mouser.com/Search/Product...538-43030-0012
Looking to make a short wip to a RJ12 surface mount plug p# 32-2036 to mount next to OBDII port.
http://www.mouser.com/Search/Product...key601-32-2036
Then use a couple of these to make a custom length cable. p# 5-555042-3
http://www.mouser.com/Search/Product...key571-5550423
( ah, sorry, I somehow missed your post of 2 days ago... if this happens then reply with a reminder, just like you did, thanks )
Good job on the parts research :cheers:
BTW: Mouser has good prices :cheers:
