drove it about 200 miles seems to be getting a bit better at not leaning out. Sometime at this car show there are tuners there maybe I'll ask them about locked pcm.
Make sure you are using the latest V8 software available here:
https://forum.efilive.com/showthread...ic-Pre-Release
Then start the V8 Scan and Tune software.
Select [F3: Tune], and attempt to read the controller. When you attempt to read the controller make sure you have "Try At Keys" and "Assume Lock May Be Faulty" checkboxes both checked. Note the controller's serial number that will be displayed in the "Detailed Information" display. Close that window.
Select the [F8: Tools] option, then the [F5: Keys] option. Enter the serial number into the "Serial Number:" field and click [Find Key]. That will search all known PCMLocks.ini files and will search on your FlashScan device for any keys stored in there.
If it does not find any keys then please send me the *.htx trace file of the failed read attempt of that controller using V8 pass-thru reading. The trace file will be created in the folder \My Documents\EFILive\V8\Trace.
when i do the read on v8 i get this at the end "Script exited with code $0537: Controller is locked with a custom key."
Send it to [email protected], include a link to this thread.
