Oops, I forgot to send the files to Tordne. Sorry for the delay.
I just sent them to him to be added to Holden Crazy.
We did a LS3. EFIlive does not recognize this LS9 auto Camaro.
Thanks.
Alex
That calibration you sent via email is supported with the latest pre-release version 7.5.6 Build 107 available here (http://forum.efilive.com/showthread.php?t=13140).
Also download the 8.1.2. Build 87 release and update firmware to 2.06.28. Also get the ZIP file in post # & of that thread and extract to the location shown in that post.
Yes get the zip file from post #7: http://forum.efilive.com/showpost.ph...40&postcount=7
Thanks guys, it worked!
can you tell me if this controller is supported. 2006 C6 Auto trans vin#********
I can advise that the E38 T43 controllers used by that VIN (which I've removed) are supported by FlashScan V2 Scan and Tune.
bfabiano,Quote:
Originally Posted by Blacky
EFILive supports the vehicle you enquired about (VIN provided by you).
However, you may have to upgrade to a supported OS... the latest one is 12614682.
Goto http://tis2web.service.gm.com/tis2web and enter your VIN, select PCM/VCM and click Next...
you will see what the dealer will upgrade your OS/calibrations to (the latest one is at the top, 12614682).
