C1:32,34 does not go to the TFP switch. It goes to the part/neutral position switch, left side of transmission where the shifter connects to. It has a black plastic housing around the shaft.
C1 pin 32+34 are not from the TFP switch. TFP switch tells the PCM which gear the trans is in hydrauliclly ( I think I just made up a new word ). C1 32+34 are PCM inputs from the PARK/NEUTRAL switch, to tell the PCM where the gear selector lever is at. Glad you got it working!
Ah, ok, the P/N interlock switch, thanks.
