Originally Posted by
twadam
Just wanted to give an update on this.
I guess the title to this thread really should have been "Innovate LC-1 installation simulating NBO2", after seeing how it progressed. After changing a few wires around and re-programming the lc-1 per Joecar's recommendation I think things are working correctly. Open loop seems to be working fine (although the voltage seems odd to me), and Closed loop now seems to run great. I've been able to dial in the VE real well with the WB. I'm not sure that it's 100% correct, but the car seems to run well with this current configuration.
Joecar, I would like to know how you knew to program the lc-1 for NB simulation. :master: I still can't find this anywhere (but it worked!).
Here's is everything I did to make this setup work:
I should point out up front that I'm using a custom pigtail on the NBO2 sensor. It basically plugs into the existing wiring harness and to the existing NBO2. Two wires still go to the NBO2, the other two are hooked with the LC-1 analog wires described below.
LC-1 red wire connected to switched power coming from Alernator (5A fuse)
LC-1 blue wire going to chassis/engine ground
Heated O2 low (pigtail from S10Wildside), LC-1 green and white wires all connected directly to pin "D" (middle external port) of EFILive interface cable.
LC-1 brown wire connected to Heated O2 high (pigtail from S10Wildside), which serves as simulated NBO2 return to PCM.
LC-1 Programming:
Analog 1 (yellow wire) -
.883V = 10.1 AFR
4.216V = 20:1 AFR
serves as WBO2 output to EFILive external interface (pin "C").
Uses PID EXT.AD2 in EFILive.
Analog 2 (brown wire) -
1.0V = 14.3 AFR
0V = 15.1 AFR
serves as NBO2 simulator back to PCM via pigtail from S10Wildside.
The results of this was:
in Open Loop HO2S11 PID showed 1.016V (this one confused me; I expected the PCM to see .445V)
in Closed Loop HO2S11 PID showed less than 1V (mimicing NBO2)
With ignition on;engine off HO2S11 showed .009V
