Regardless the source of the problem, I solved it by calculating what I wanted my shifts to be at and set the mph at the high end of the part throttle tables, set 1206 and 1207 so they were unattainable and after one test so far it is working, clicking off nice 5500rpm shifts... will report back if its still acting up or if i learn anything more. now after I go to the track i can finally start tc tuning:) Thank you for the insanity check!
