Connected the LC-1 to the scanner this week and did a short logging session. Yesss, it worked! My wideband scan shows about .1-.2 lower than the XD-16 gauge. I assume the gauge is correct since it has a digital connection to the LC-1. I'll need to fix that, but the results are still pretty darn close.
So back to topic... Looks like I'm averaging around 13.5-7 AFR at idle. It seems to bounce all over the place. This was in CLSD so the front O2s/LT headers are probably causing some of my richness. Next step is to turn off the O2s and do my first OLSD AutoVE tune.
On a side note here's a summary of my WOT readings:
Holy smokes! It leans out like a big dog past 4800 rpm. Shouldn't go any lower than 12.2 or so on the upper RPMS, but I'm seeing 13.3.Code:RPM Commanded AFR Error
3600 10.006452 11.3 13%
4000 10.006452 11.3 13%
4400 10.006452 11.6 16%
4800 9.907182 12.0 21%
5200 9.822727 12.8 30%
5600 9.571667 12.9 35%
6000 9.571667 13.3 39%
