Base on what I see and what little I know, I would lean toward the Innovative system vs PLX Devices. The PLX SM-AFR as an example, needs to to modified to add a DB9 to work with V2 while I believe the LM-1 is already setup with a serial port and would only need a cable. I understand the LC-1 will also work easily but I am not sure what is needed for the LC-1.
http://forum.efilive.com/showpost.ph...1&postcount=60
http://forum.efilive.com/showpost.ph...7&postcount=10
http://sodoityourself.com/max232-ser...vel-converter/
http://forum.efilive.com/showthread....ghlight=serial
