There is no recovery if EFILive_Explorer cannot see the FlashScan unit.
Please send it back to Fish Tuning to be reprogrammed manually.
Contact details for Fish Tuning are on our resellers web page.
Hi Paul,
I just tried some logging on the E38 using the DMA Pids. As soon as I try to log data or display data I get the following message...
Node: ECM
PID: APCYL_M
is not supported,
please de-select it.
Did the DMA PID's change names again? I checked the PID description file and it seems to be correct.
Simon
My guess is you're copying too many files and filling up the CONFIG file system (its not very big). I can see old *.pmm files that should have been deleted. I recommend deleting ALL *.pmm files from the Config folder on the PC. Then re-extract them from the latest zip file. Then you'll have just the latest set of files - without old files from previous releases.
When you send a new time to FlashScan, if that new time differs from FlashScan's time by more than 1 second it will update the flash memory with the new time.
When you attempted to update the date.time did the blue LED come on? (i.e. indicating that it was updating the flash with the new time)
If it did, it may be that it took longer than 5 seconds to write the new time to the flash memory (although I can't think why it would take that long).
Do we need to copy all the .pmm files to the Config tab, or can we just copy the one(s) that pertain to 1 vehicle (e.g. LS1B_A.pmm)...?
Edit: see my Options.ini file in my next post #40...
Paul,
On the V2 menu, instead of saying "Select Vehicle" it should say "Select PID List".
For example, in my Options.ini you will see that I have different pid lists for the same vehicle:
Code:; _______________________________________________________________________
; | Copyright © 1999-2007 |
; | EFILive Limited |
; | web: http://www.efilive.com |
; | email: [email protected] |
; |_______________________________________________________________________|
; Modifications
; _________________________________________________________________________
; Version | When | Who | Why
; 8.0 | 2007-Feb-16 | PSB | Created file
*VEHICLES
;Vehicle selection list
; Cap1 and Cap2 form the "on-screen" display option from which the user may select.
; Controllers lists 1 or 2 "&" seperated pid memory map (*.pmm) files.
; PSL is the PID Selection defined later in this file
; PCU is the PID Custom Units defined later in this file
;Cap1 Cap2 Controllers (Engine&Trans) PSL PCU
A->, O2S, LS1B_A.pmm, PSL_A, PCU
B->, LTFT, LS1B_A.pmm, PSL_B, PCU
C->, TRANS, LS1B_A.pmm, PSL_C, PCU
D->, LOOP, LS1B_A.pmm, PSL_D, PCU
; PID Selection List
; Node: Is one of PCM, ECM or TCM (use "-" for external PIDs).
; PIDs: Is one or more "|" seperated PID names. The first valid PID will be used.
; Alarm: Is 5 ":" seperated fields:
; min: Minimum value, below which the alarm will sound.
; max: Maximum value, above which the alarm will sound.
; style: Is one of:
; 0 = No sound, No LEDs
; 1 = Low pitch
; 2 = Medium Pitch
; 3 = High Pitch
; 4 = Very high Pitch
; 16 = Illuminate LED 1
; 32 = Illuminate LED 2
; 48 = Illuminate LED 3
; 64 = Illuminate LED 4
; 128 = Illuminate LED 5
; Add Pitch and LED values together to enable audio and visual alarms.
; For example, for Medium Pitch and LED 4, use 2+64 = 66
; time: Time (in 10ms increments) for which alarm will be sounded.
; hold: Time (in seconds) for which the displayed value will be frozen (not implemented yet).
*PSL_A
;Node PIDs (pid1|pid2|...|pidn) Alarm (min:max:style:time*10ms:hold*sec)
PCM, TP
PCM, DYNCYLAIR_M
PCM, MAF
PCM, DYNAIR
PCM, GEAR
PCM, ECT, -40:110:97:1:0
PCM, RPM
PCM, EQIVRATIO
PCM, HO2S11
PCM, HO2S12
PCM, HO2S21
PCM, HO2S22
PCM, SPARKADV
PCM, IAT
PCM, MAP
PCM, KR, 0:2:147:1:0
PCM, TCCMODE
PCM, MFTOTAL
PCM, VSS
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_B
PCM, TP
PCM, MAF
PCM, GEAR
PCM, RPM
PCM, EQIVRATIO
PCM, HO2S11
PCM, HO2S21
PCM, SPARKADV
PCM, IBPW1
PCM, IBPW2
PCM, IAT
PCM, MAP
PCM, LONGFT1
PCM, LONGFT2
PCM, TCCMODE
PCM, MFTOTAL
PCM, VSS
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_C
PCM, TP
PCM, DYNCYLAIR_M
PCM, MAF
PCM, GEAR
PCM, RPM
PCM, EQIVRATIO
PCM, HO2S11
PCM, HO2S21
PCM, SPARKADV
PCM, IAT
PCM, MAP
PCM, SHIFTLAST
PCM, LONGFT1
PCM, LONGFT2
PCM, TFMPRS
PCM, TCCMODE
PCM, MFTOTAL
PCM, VSS
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
*PSL_D
PCM, TP
PCM, MAF
PCM, GEAR
PCM, RPM
PCM, EQIVRATIO
PCM, FTC
PCM, FUELSYS
PCM, HO2S11
PCM, HO2S21
PCM, SPARKADV
PCM, IAT
PCM, MAP
PCM, LONGFT1
PCM, LONGFT2
PCM, TFMPRS
PCM, TCCMODE
PCM, MFTOTAL
PCM, VSS
-, WO2ST1
-, WO2ST2
-, WO2LAM1
-, WO2LAM2
-, WO2AFR1
-, WO2AFR2
; PID Custom Units
; PCU specifies the controller and PID for which to define a custom unit
; Caption is the caption displayed on screen during BB logging (8 characters maximum).
; Prec is the number of decimal places to display
; Units is the display units name.
; Op is the operator, one of:
; * = multiply
; / = divide
; i = invert_then_multiply
; The metric value of the PID is multiplied, divided or inverted then multiplied by Factor.
; Offset is then added.
*PCU
; PID Caption Prec Units Op Factor Offset
PCM,MAF, AirFlow, 1, lb/m, /, 7.559873,
PCM,MAP, Manifold, 1, psi, /, 6.894757,
PCM,TFMPRS, Trans, 1, psi, /, 6.894757
PCM,VSS, Speed, 0, MPH, /, 1.609344,
PCM,EQIVRATIO, AFR, 3, AFR, i, 14.63,
PCM,ECT, Coolant, 0, °F, *, 1.8, 32.0
PCM,IAT, Intake, 0, °F, *, 1.8, 32.0
-, T1, T1, 0, °F, *, 1.8, 32.0
-, T2, T2, 0, °F, *, 1.8, 32.0
