Here's an example I pulled from my LS1B... it shows the states of the continuous/non-continous monitors (I xxx'd out my VIN).
Cheers
Joe
:cheers:
Edit: I had the wrong attachment, now corrected.
Paul,
You may have to post what all the characters in "M-PHX-CS" mean in regards to the state of a DTC.
Thanks,
Joe
:cheers:
I have another update for this. I stated logging this afternoon and very quickly the V2 dropped into "pause" mode. I tried pressing the pause button a few time and found that if I held it down, it would drop out of pause mode and start to log, but go straight back to pause mode as soon as I let go.
I then reset the V2 and started logging again but some time down the road it again went into pause mode. Hitting <cancel> saved the log file, but it is just the first 2K of the meta-data.
Simon.
I know that the main focus is DVT & Standalone logging but I found some weird things some have gone on for a while the first one is GM.EGR this is the actual position of the egr. When logging with the egr enabled I beleived it worked a long time ago. Now if I use it with the EGR tuned out it shows 100% all the time if it was actualy at 100% the truck would smoke real bad but all is well with the truck. The other ones are SAE.MAP and GM.MAP2 these don't read the same wich one is the best to use for reading boost? Usualy wich ones are better for logging also SAE. or GM. ?
Code:S: Supported DTC is supported on this vehicle.
C: Current DTC is currently set.
N: Not Passed The test for this DTC has never passed since it was last cleared.
X: Failed The test for this DTC has failed at least once since it was last cleared.
H: Freeze frame Freeze frame data exists for this DTC.
P: Passed ign The test for this DTC has passed this ignition cycle.
F: Failed ign The test for this DTC has failed this ignition cycle.
M: MIL MIL is illuminated for this DTC.
