Throttle Position, Throttle area and Drilling holes
I've been playing in Excel a bit to try and confirm . deny a theory I came up with when talking with Mike yesterday. My theory is that the E38 uses both absolute throttle blade position and effective throttle area (as a percentage). But there is no indication as to which is being used when. This helps explain the old PE TPS graph that I went through a couple of years ago.
Anyway, I've been plotting the data out and it seems to fit in a general sense, but it's not quite there. It has helped explain a little about the hole drilling method though....
When calculating the absolute blade position and comparing it with the effective throttle area, we see that at low throttle openings, the effective area rises sharply compared to the blade position. This is because the blade tip moves through an arc from the top / bottom of the throttle body, toward the centre line. The throttle effective area is then the "gap" between the blade and the inner surface of the TB. Initially this gap widens quickly, but after a certain point (about 35% of blade position) it slows down and the change in effective area nearly matches the change in TP %. Then a short time after, the effective area changes slower than the TP% (about 65% of blade position ).
How this relates to the holes in the throttle blade can be seen when looking at the nominal Idle TP%, seeing the matching effective area and then looking at what the hole does to the situation. Here's an example.
My car normally idles at around 6% as indicated via the ETCTP PID. This gives me 8gm/S of idle air and all is well. At this pint I have an effective throttle area of about 21mm^2 which is 0.44% of the total throttle area.
If I drilled a 5mm/Dia hole in the blade, I'd introduce an additional 20mm^2 of effective throttle area, which would double the effective throttle size. So I'm going to assume the ECM will almost close the throttle to maintain the desired airflow. At this point, the ECM can not 'reduce' airflow, as it can't block the hole in the TB blade. So you have effectively removed the ECM's ability to reduce the airflow below this point.
Personally, I've never drilled a hole, possibly because I've never had a car with a big enough cam to need it. We know that the E38 likes to over feed the motor with air, as the engine seems to idle better, so the hole seems a good method to hard limit the minimum air flow. I'm pretty sure you can still do it in the software, but you can't make the hole smaller in software....
There are a couple of other things I'm still pondering....
The difference between {B1650} and {B1701}. One is set for a 78mm dia throttle and the other for a 102mm Dia throttle. Why the difference? Something to think about.
Simon.
