Will this work on a 2004 lly, right now my truck is dead and won't turn over, this all happened when i was install my efi into the ecm that had a custom tune already in it.:wallbash:
Are you using the latest software and FlashScan V2 firmware available here?
http://www.efilive.com/index.php?opt...=48&Itemid=133
If so please provide the appropriate trace files as explained here:
http://support.efilive.com/kb_articl...8254-QOGC-9586
Thanks for the log files. They show the ECM is not responding at all. Chances are the boot loader is still running in the ECM. Disconnect the battery for 30 seconds, reconnect and try reading the ECM again.
Just for future reference: The LLY ECM has a built in boot block that is not erased during the flash process so it is ok to disconnect the power if a flash fails (even a full-flash), it won't kill the LLY ECM. The LB7 (and other older/other gas controllers) will most likely be rendered inoperable by removing power after a failed full-flash.
I just pulled the ECM out of the truck tonight, i tried disconnecting the batterys last night and it still didn't work, i talked with Monte at ATP and they said they should be able to get it working doing a bench tune.
Still having problems with trying to get my truck to start, checked the fuses under the hood and don't have any power to the EDU fuse or the ECM fuse would this be caused because the ECM is not working or do i have other problems other the the ECM, "HELP"
so dose this mean the ecm and the ecu send power to them fuses?
Thanks for all the help i finally got me truck to load the tune and it started up right away, my remote start was stopping it from down loading or interfearing with the download, and no problems truck running great.:jump:
