Thanks Ross
Jake
Thanks Ross
Jake
So, I downloaded the new .calz files and when I opened up the tune tool a window popped up saying "unrecognized pcm" and some other stuff. Now my tune tool is useless. I cant open up or change any of my tunes. I tried deleting the .calz files (the cmb folder was empty originally) and that didn't help at all. What do I do now!?
Mike
Personally, I'd recommend downloading V7.5 again from www.efilive.com and re-installing it. That should clean up any problems by messing around with the calz files.
Ira
I re-installed v7.5 and it is working again. Thanks.
Mike
Sometimes internet ISP's can have issues when you download a file and it get corrupted evertime no matter what you do or what archive software used to unzip. This can be resolved with your internet provider. Not usually the case but ive run into this same issue over the years.
understandable, the attatchment worked perfect.
So, am I just out of luck then?
Mike
Sorry, I should be more clear. The 7.5 tune tool is now working fine after reloading it - without the .calz updates. As soon as I download the updates, the tune tool stops working again. I have tried it three times.
Mike
