How does this table work if you run SD? The table values are ran off SAE.MAFQuote:
Originally Posted by SSpdDmon
Thank you.
Thank you.
GM.DYNAIR reports grams/second.
Updated...Quote:
Originally Posted by 2002_z28_six_speed
How does A0014 (IAT VE) interact with A0008 (ECT Commanded fuel) do they multiply on top of one another?
Quote:
Originally Posted by zapp168
That's how the air mass is calculated. Then based on the commanded fuel, current RPM, and other constants in the tune, an IPW is determined based on what the PCM knows to be true about the injectors.Quote:
Originally Posted by EFI Live
A0008, IIRC, simply multiplies the VE by the appropriate value to inflate or deflate the air mass calculation.
A0014 mulitplies the VE table(s) B0101/A0007.
A0008 multiplies the Commanded Fuel table B3647.
Links to other discussion on A0014:
showthread.php?t=5563
showthread.php?t=7132
Anyone ever figure out why this table runs opposite to what one would think... i.e. needs richening up when hotter IAT and leaned out when cold IAT? Exactly opposite of what my logic says - need more fuel when IAT is colder...
Hi BLK, it seems nobody has figured it out, yet.
Hey! Thanks Joe! I've never had time with a car to log it under many IATs and figure out what these guys have - I've been using it backwards...
