It could be that EFILive is searching for multiple cable types before finding the correct cable. You could try setting the exact cable type that you have in the EFILive Scan Tool to force EFILive (both scan and tune) to only search for the cable you have.
For example, if you have a FlashScan V2 cable only (and don't need to scan for other cable types) you should have it set like this:
Attachment 15596
Note: The V7 Tune Tool must not be running when you make the change. You also need to close the Scan Tool to cause the changes to be saved prior to re-starting the tune tool.
