Here you go, I have a bunch of them. Read them out whenever I get a A50 in the shop.
Attachment 18097
Attachment 18097
I swapped OS's twice on a 2010 A50, took it out of my 2010 full flashed it with a 2011 OS stuck it in the 2011 with no issue's pulled it back out and flashed it back to the 2010 OS and put it back into that truck with no issue's, when the new TCM showed up for the 2011 I full flashed the correct OS for it with no issue's either. All trans flashing was done in the V8 software though.
Thanks for confirming this. If you say V8 works fine I'll attempt it tomorrow, I'll do it on the bench too. At least I'll have trace files this time. When I had them issues I used no computer, just the Flashscan V2. Maybe the problem lies in the scripting/configs for tool only flashing. I was confused after finding this thread because others mentioned needing to go to a dealer to full flash. I went through again and didn't notice the A40 got thrown in the mix. I skimmed really quick first time and the thread is titled "2011+ TCM Full flashing".
Sorry for the confusion- we should have started a new thread I guess. Some of us want the ability to do a full read on TCMs with EFILive so that we will have those specific full files to full flash into NOS TCMs (new blanks) or used TCMs that need a full reprogram. This will allow us to do what we currently have to get a GM dealer to do, or at least someone with the dealer level programming stuff (TIS). As of right now full file reading cannot be done on any TCM with EFILive because there is no "full read" button to click on in V8. Once that ability is given us a full read can be done on any TCM that has a full read script written for it.
I guess I was the one confused the most- glad you set me straight.
I just flashed the new A50 controller and everything went fine.
Using March 3,2015 release.
My only issue is. I can't for the life of me add the new Vin #. I see you can change it for the Tune file, but that doesn't load to the TCM. V2 pass through using the EFILive Tune/ PCM Security doesn't work and change Vin # in EFIlive Scan and Tune doesn't work either to update the TCM.
Any suggestions??
