X2 with the boost referenced regulator.
I don't know if that MAP sensor is suitable...
yes i have..:D im not new to turbo charging, supercharging, fast programs, or holley fuel injection...but efilive is new to me...i know the numbers to shoot for, just now how to setup the program up to get there.....
the wideband is off.....im trying to figure out how to adjust...ive had a hard time callculation my injector data...
80 lb sure fire injectors based on 43 psi
fuel pressure is 70 psi..not sure why...i think my pump is too big for stock lines
i will connect the stock pressure regulator...ive read wherte a stock 99 silverado one will work with boost.
thanks
EFILive hints:
- set VE units to g*K/kPa,
- set fueling units to EQR,
- set PE sufficiently rich to be safe (and make sure it will enable),
- log GM.EQIVRATIO,
- use wideband Lambda for correcting VE and/or MAF tables (might need a calc pid for it),
- disable MAF and trims, correct VE table;
- disable VE and trims, correct MAF table;
More info, see posts #2, #4, #29, #38 in this thread: Summary Notes
There is a thread on how to correct maf and calculate ve. Inside the thread shows how to setup calc pids to use analog signal and use it with eqr and lambda. I think
