The multiple serial port logging is no longer being developed. Instead we will be offering the FlashScan interface which provides 2 A/D converters that can log analog signals from *any* sensor - not just those that provide a serial data stream.
While we were protoyping and testing the multiple serial port upgrade for EFILive we discovered a number of drawbacks including:
- Not all aftermarket sensors that customers may want to log provided a serial data stream.
- Those sensors that did provide a serial data stream were proprietary formats which meant we would need to code EFILive to support each type of sensor individually.
- The serial comms routines in EFILive would have to be rewritten.
- We are standardising on USB support so the serial interface to EFILive will no longer exist.
With the new FlashScan interface the extra A/D inputs will provide far more flexibility and allow customers to integrate many more external sensors than just a few select wide band O2 sensors.
For example: Dyno output, super charger boost levels, extra temperature sensors, external accoustic microphones, extra pressure sensors, in fact just about anything that produces a 5 volt signal can be logged.
