DFCO is there already, but I want to kill COT and the P1481. But that might change here in May, might not even need the P10 files but will need the P12 ones...
Quote:
Originally Posted by ScarabEpic22
Did you ever find out if we can use the newer pcm's in our 2002's ? i know that on trailvoy you were talking abuot maybe checking the pinouts and having a maf installed to replace the iat sensor....
Also, where can we get a hold of the boys here so we can force them into a dark corner and make them deliver the goods for our p10's ?
I want my codes disabled...
BTW: If any of you were thinking of getting the tune from pcmforless, then using hptuners to disable the p1814 DON'T, hptuners writes over the efilive tune in some of the mem areas as per my understanding...
Interesting about HPT overwriting some EFILive code, havent heard that before. must be just how they are cracking the code or something?
As for the first question, Ive looked at it a little more but nothing is going to happen until at least May. Right now my folks aren't willing to give me my TB back so Im not sure if I will get a chance to do it and not sure I want to spend more time if Im going to sell my mods and buy an 08 TB SS instead...
OK guys, Jesse's said the new .cals have been ready for 2 months now. Any update as to when we as end users can get them? Im going home this friday and really want to be able to pull the COT and do a couple other things...
And I talked to HPT, for the P10 they have a Diagnostic Parameter that deals with what RPM the P0068 code comes into play...whats your opinion on this? I think we can kill the param that lets the test run but they have an RPM setting and I dont know whats up with that...
I just want to be able to make my TB faster! Arrggghhh
They should be in the next update, but email if you would like, and i will get you the files you need. It has all the stuff you need.
PLEASE!! Sending an email now!Quote:
Originally Posted by wait4me
Thanks a ton Jesse!!!:cheers: :master:
Edit:
Where should I sent it? No email addy in your profile, only one I can find is hannahbubb AT yahoo.com for payments...
Thanks man, email sent!
so do we have an efi update for the P10?
The update's in the latest release of the software.
Also, today with v7.5.4 and the latest BBL firmware I couldnt do a CASE on a P10 I6. Went so far as to reinstall 7.5.3 and try, no luck. Any idea when DVTs will be available for the P10???
