Sweet! Thanks paul
When the switch tune option is avail, will it include RoadRunner functionality also?
That would be awesome.. RR and v2... I have asked for this.. haven't I paul?
RR and V2 (without needing a laptop?) yes it's been requested many times. It is not a high priority but it is something we'd like to implement eventually.
I could really use the ability to run the automated ABS bleed procedure from the flashscan.
printing option would nice
I could really use BCM editing ability.
I understand that there advantages with the wideband being on a serial port instead of going through analog to digital converters. But the problem is that I have a V1 and I don't want to spend $550 to upgrade to a V2.
My AEM wideband has a serial output that I can wire up to a DB-9 connector, is there a way that EFILive can be integrated to use a program like "HyperTerminal" to record the AFR input from a com port instead of reading it as a 0-5v external voltage? Just an idea for some of us without V2 that still want the advantages of a "direct" AFR.
Not sure if this will even work but it would be nice for some of us perfectionists. :) A few extra wires while tuning but what one more? hehe :D-CoryF
You can probably get a Digital Analog converter and convert the serial WB into analog, but then you probably have the same problems with ground offsets again.. (ie) Save for $550 :)
