Yes, you can change it by adding an entry to the *PCU section in Options.ini. Use 1.0 for the factor and 0.0 for the offset since the value should be ok, just the units text needs changing.Quote:
Originally Posted by joecar
Then select "Custom" units display in FlashScan. While logging, "Enter" toggles between Cutom and Metric units.
You can do that for any PID. Using the correct values for factor and offset you can change any PID to be displayed in any custom units that you would like.
I have fixed the units for the next release.
