Is the firmware wrong ?
Says May 12th, 2008 .
Just re-flashed and now says May 19th, 2008
Thanks , for the help that was it .
Yes I figured the May 22 was next unreleased update date , see above .
Don't know how I missed and selected the wrong update .
Man have to many things going at once !
When i try the latest update to BB log. i choose pids eg LS1B A and then go to start logging and it says no pids selected. I notice that after i select pids it changes whats displayed as VPW to ALDL.
Is there something wrong with the update or something i can do at my end.??
Yes I am
I was just wondering if logging serial wideband in pass through mode is up and running. I was keen to see how this operates with RTACS?
Is this something that is currently being worked on or tested?
Serial input and output for Dyno's, has anybody tested this yet, as I see it is selectable in flashscan next to the wideband?
I have a little testing to do on a Superflow Engine Dyno that I have been working on for the last couple of months and it's all starting to come together. Support for this Dyno and serial input and output, is there any chance?
Do you require Dyno information? Will this help any?
Hummm I do ask a little, but the time has come....:angel_innocent:
Cheers
Mick
last week i got a mainline dyno outputing serial in to my V2 cable , i have installed a second rs232 port on the dyno PC in ready for the update from Andrew . i have not had and news from Paul or Andrew in the last 3 weeks so i take it there still working on it
That sounds great Geoff!
Thanks for the update on the Dyno setup at your end.
Were you able to log data from the Dyno into flashscan in a usable sense were you could review the log file?
I would guess that Dyno protocol is much the same if not more complicated than wideband and support for various Dyno's will be something further in the future.
Good work!
Cheers
Mick
