The algo will not be stored anywhere in the bin file or the cpu. It is just a number put there by the manufacturer, but you need the algo to find out what number they put there.
I guess I don't full understand. So the Bin will have a number, the number is sent to the software which calculates a response based on the algorithm, and then sends it back to the ecu to gain access? Can't I get that seed number off of a stock unlocked ECU if I know the hex offset and transfer that to my locked ecu?
Eric you will need a match set
So in the BIN are a matched set seed&key. The software calculates a key from the seed, which matches the key in the bIN? If I grab a ecu from picknpull for 25 bucks I should be able to get a matching pair from reading the BIN?
Send me the file and I will fix it
