Vista
Vista
Let me try to help...download zip folder to your desktop first.
Then right click on zip folder...click on extract all. Should bring up a screen that allows you to choose where to extract to. Click on browse, drive c, program files (x86) if your running 64-bit. Click on EFI, click on v7.5, click on calibrations, click once on CMB. Go to bottom of screen and click ok. Toolbar should say. C:/programfiles/EFI/7.5/calibrations/CMB.
Or similar layout....click extract all...should ask if you want to replace file with new one, click yes to all and it should replace all OS calz files with new ones.
Hope this helps.
~Les
This is a sore subject. Plea research the latest threads.
This is true..Ross accomplished the same result without tricking your ECM into thinking it's a manual truck and losing your shift indicator lights.
~Les
EFILive enables the end user to correctly modify and tune their truck while box tuners may take shortcuts that may be viewed differently when read out with EFILive.
You beat me to it Les.
Seriously?
