I can't make the CVN's show up as zero on my test LS1 here. Can you make them show zero on yours there, then save a trace file and send me the trace file, thanks?
Quote:
Originally Posted by Blacky
It should not show as zero - that would be a bug. What controller was that CVN display taken from?
Can you make that happen again? If so can you save a trace file and send it to me thanks.
The dates show up correctly on my test system here.
I presume you meant the "Set Now" option in EFILive Explorer (not HAPI)?
The date/time stored in the file should be within a few seconds of the file's actual date/time stamp.
Can you double check that setting the date correctly still causes the wrong date to be stored in the file?
June 11th, 2013
joecar
1 Attachment(s)
Quote:
Originally Posted by joecar
Also, for an unsupported OS, the CVN's part number reads as zero (but this doesn't really matter, unless it's a bug), see attached:
