From what I can figure out, if the table is running opposite it means either your IAT sensor is either suffering from heatsoak, or your charge temp blending is in error. Personally I leave this table set to 1 in the cells the IAT normally will run in during the year. Then just change the extreme areas where you know it is a heatsoak condition causing an incorrect AFR.
