Can post the AEM user manual pdf here...
Here is what 400ss is referring to (see post #1): Calc.MAFT thread
This is also helpful (both Calc.VET and Calc.MAFT thread refer to this also): Calc.VET Summary Notes
Has anyone opened a log to see what's there?
Sorry for being unclear... Has anyone figured out why when I save a autove map, then reopen that table shows invalid numbers?
No one else is having that problem, hence why we need you to post your log file to have a look.
I would be extremely confident that the problem is in your map settings, ie you are logging the wrong pids. Once we see your logs raw data we will be able to sort you out.
If your BEN_PLX map shows 10.7 (see post #37 above), then when you paste-multiply you will very likely exceed the VE cell max range.
Post log file, and the tune file that the log was taken from.
Post #20 is my pid file.....and you guys need a ve log...coming up in a couple hours when I'm at work.
