Yes, pulled both negatives off the two batteries.
Ok, I see Paul has sent you some stuff to try.
I got a new set of files from Paul for v8 that allowed the v8 program to wait long enough to recover the ECM. Thank you!
Hi Rob,
Sorry for the lack of reply, for some reason I had not noticed your post.
That is a confirmed bug. The software is incorrectly attempting to stop data logging on the vehicle even when no vehicle is connected. An update is planned for mid next week.
Can you please send a log file that contains the EOP PID so that I can try and replicate the same issue here.
Here's a log file: Attachment 18442
I played with it some more.
- open log file
- added my calc pid to selected list
- go to data view and start playback
= calc pid sits at 0 even though EOPS has varying voltage
- edit calc pid
- don't make any changes
- click ok
= calc pid now works
If I open the same log file, add the same calc pid, it doesn't work again and I need to do the same open / save of the calc pid.
I don't know where the calc pids are stored but if you let me know I'll attach it as well.
Thanks!
Rob
In V8 user defined calculated PIDs are stored here:
\My Documents\EFILive\V8\UserCalculatedPids.ini
In V7 user defined calculated PIDs are stored here:
\My Documents\EFILive\V7.5\User Configuration\calc_pids.txt
If you can send me the appropriate calculated PIDs file and athe log file that you are using I'll see if I can see why its not working.
Send to paul@efilive.com
More info:
It looks like the issue happens to whichever of my calc pids is added last to the Selected Pids. So its not one specific pid.
I found user calc pids in slightly different location: My Documents\EFILive\V8\Config\UserCalculatedPids.ini
I don't seem to be able to attach the calc pid file with the .ini extension so I changed it to .txt.
