send it to "socaldiesel at earthlink.net"
How are the defueling issues coming guy's? I'm trying to get geared up for my first pull this weekend I'm just wondering how this is gonna effect me.Thanks Jason
No luck so far. I can get mine up to 4k(at least) but no power there.Quote:
Originally Posted by 1DURAMAX1
With my built trans and racing, I don't have to worry about it now because it shifts around 3200-3300rpm.
Good luck at the pulls, might want to keep it in a gear where you won't see 3400, even though it hard to pull that way.
Quote:
Originally Posted by IdahoRob
I'll be pulling in 3rd gear with 315's I will probably top out around 3500rpm's. That's a complete guess since it will be my first hook with this truck. Thanks for the help Rob. Jason
You will probably be ok with turning up all the tables mentioned. I pulled with mine, tach sitting on 3400-3500, never sounded or felt like it went to defuel, or if it was, just enough to keep the rpms at 3400-3500.
I really should have logged the pull, just a suggestion, helps set you up for the next one a little better.
Bump. Any new news on this issue?
Just today released an updated Beta version with 6spd TCM reading/flashing (that worked!!). Should have some news shortly.
Is that part of the beta release that is up today or is that a new beta release to your beta testers?
I didnt see any note of the 6spd in the post for the beta that was released today.
In Pauls post in the beta section he does say that it includes the Allison update.Quote:
Originally Posted by Cobra#3747
must have missed it...Thanks again
