Run the program regedit from Start->Run
then starting from the top of the registry search for EFILive, and delete it, then exit regedit
( be careful you don't delete anything else )
going through the start->run, a search box is provided and it could not find Efilive, I also have revo uninstaller & Efilive is not there either?
and going to the windows uninstall both efi & V8 are gone
Ok, using regedit you have to remove any EFILive keys from the registry
( Start->Run and then enter regedit in the search box )
the only thing I found was efi, no v8
In the registry search for and delete any trees named "EFILive".
thank you, I just had not gone down far enough. I got them all deleted now
just an update, I tried to install the new software and was turned down again., still says earlier version is not compatible & must be removed, but when i click ok to remove the same script error appears, thanks john
In the Program Files folder delete the folder EFILive.
still have the same errors:wallbash:
