Thanks for the info. I only do it to my truck and being that I just got a 10 lmm I wanted to make sure before I update. Again thanks.
With a lmm you are fine
I'm a newbie here and to EfiLive. I recently installed a new DPF (long story) and the exhaust guy messed up and welded the pressure sensor due to a stripped plug. Ive been having troubles since, the worst is that the egr is on all the time. I pulled the solenoid and it seems to be working properly, but it is fully extended when the engine is running.
Instead of replacing the solenoid, I put it in the glove box and taped off the wire. The engine is running much better :) I need to smog in a few weeks, so I'm looking for a replacement DPF. I've got the V2, but I'm still going through the manuals and plan to tweak the tuning after smog.
Question, Is it going to be ok to drive without the solenoid for a few weeks?
Is this USA only restriction still the case? and if so, does it apply to the new V2 HD as well?
Answered in the other thread you started.
Yes for the HD, but is it still available outside the us for the regular v2?
I still have my old efi live that I haven't used since probably around 2010. I have software on a couple old laptops. This hasn't been updated. Someone should still be able to use for DPF delete, right? I don't want to update it and lose the ability.
I am sure I am not the only one wondering this, but with the emissions restrictions potentially being eliminated in the US could we potentially gain access to emissions files if everything goes through?
You cannot gain access to anything that is not actually been mapped...........and I can tell you its not mapped by EFI-LIVE
So even if the EPA stops enforcement and the emissions standards are repealed, etc............IMHO, they are not going back into the binary and mapping these missing items out.
You will need to find it for yourself or find somebody who can do it and pay them for their expertise
