Fix this:
Quote:
Out of Range calibration summary: 04:00:37 am, Friday May 22, 2015
Engine Calibration.Abuse Management
{B1207} Abuse Management Vehicle Speed Threshold, was out of range when loaded.
Fix this:
Is your FPR manifold-referenced or un-referenced...?
Thanks for the quick response Joecar!
No they don't, see screen capture below:
http://i19.photobucket.com/albums/b1...psuopkuico.jpg
Okay, I'll do that. I did the math on a calculator and couldn't get it to line up either.
One thing I noticed, the temps dob't look right. The dynamic (DAT) air temps are negative and/or really low. But the IAT sensor looks accurate. Weird.
Just did - thank you.
Vacuum in not-referenced. Using a corvette-fuel filter a few feet off the tank with a single line to the rail.
If GM.DYNAIRTMP_DMA pid is returning bad values, then for now use (temporary solution) IAT in place of DAT, and do take a look at how to create the pid CALC.B4901 in the Calc.VET thread.
Ok, so your FPR has no reference hose going to the manifold (or any source of vacuum and/or boost).
I see it in your log, your CALC.DAT being wrong is causing bad CALC.VET.
I found the calc_pid text file with 4901 and replaced the old calc_pid file. That seems to have fixed the DAT.K temp issues. However, the values still seem really low. Based on the LTFTBEN, I should be multiplying the values by 1.05-1.10 (increase of about 10%). However, on the BEN calculated VE, I should reduce the values by about 25%. See screen capture below:
http://i19.photobucket.com/albums/b1...psuexb1fiv.jpg
http://i19.photobucket.com/albums/b1...psrx8zeqwm.jpg
Here is the VE table I was reffering to when I was comparing the calculated values in the MAP and the values in the VET table.
http://i19.photobucket.com/albums/b1...ps597rhtli.jpg
You haven't applied the transient filter... but I don't think that's the problem.
How is the MAF table coming out, post a pic of it.
You show two maps:
1. VET [g*K/kPa] x MAP x RPM,
2. LTFTBEN [%] x MAP x RPM,
are you calculating the VE or are you correcting it...?
Is your IFR table correct for the injectors...?
You said FPR is un-referenced, right...?
Measure rail pressure (in psi) at idle, and observe pressure as you snap throttle open and then shut... what did rail pressure do...?
I added in the filters and the changes were minimal.
Pic of MAF MAP:
http://i19.photobucket.com/albums/b1...psdw68svfw.jpg
I was trying to show that the correction shows to add between 5-10% to the VE table. And the calculated numbers in g*K/kPa suggest to lower the values in the VE table by way more than that, almost 30%.
Injector values are stock and correct.
Yes, unreferenced. Corvette fuel filter close to tank with no manifold vacuum feed.
I'll borrow a fuel pressure gauge and try to get a read as you described.
