Please explain what you found...
~Moderator~
I found in some E92 cars if you rise the torque tables too much it will go out of PE for some odd reson
I dont have my laptop right now to check your file but could this be the reason
Weasam, thank you for the heads up. I may go back through the file and put in some more realistic numbers, now. To prevent that.
Joe, I had to go throughout ALL of the Cat over temp settings and, basically, max them out.
It looks like GM decided that if you hit any of the criteria (even during PE mode) that the car would command stoich!
After I went through every single setting and disabled or maxed out the settings, my power came up and I was able to go to redline!
