I updated my post #56 with a little different information regarding 07 P12 I6s. Finally got verification what setup they use.
I dont sorry, easiest way to tell is the 04-06 P12s are 1MB flash and 07s are 2MB. They both read out using the same bootloader so read it out and the software will tell you what it is. Or Im betting you could pull the calibration information using the Tune tool's PCM information window.
Here is the file from the DBW 2000 Chevy Tahoe I was reffering to. I don't have the file from the 01 truck but it was also equiped with traction controll, auto ride or active ride suspension and DBW. Never seen it on earler then 2000 LS1B Vehicals. Can get a 99 or 2000 vette too also equiped with DBW.
Hello 1FastBrick,
That tune uses OS 12205612 (2000 truck). I have a 2000 DBC truck tune on file that uses that OS. Early DBW setups typically used their own unique OS. The Vehicle Platform Options in that tune file has "Electronic Throttle" denoted as "Yes".
Did you read the tune from the vehicle yourself, and visually confirm it was DBW ? The reason I ask, is that "shared" or "internet" tune files are often altered / corrupted in various ways.
I have never seen a 2000 (non 8.1 L) DBW truck in my area of the world - if they exist, they are rare indeed.
Regards,
Taz
It has to do with traction controll and the autoride suspension. That 01 truck has it too but it been extensively modded and no one has the original OS file any more but I could get the vin number and you could check it out if you wanted too
Were all the LS1B Equiped 99-up corvettes DBW ??? If not I just pulled the calibration from one that is DBW from The Shop next door....
Oh and BTW TAZ I own a 2000 silverado that has that same OS but Is DBC so i understand the confussion. When this customer first brought in this tahoe I was like what the Heck I have never seen that before??? then i found a freind that bought that 01 truck that was also equiped with the DBW. We found out it was because of the traction controll and the auto ride or what ever they call that active susspension in the Suv's there few and far between. I am in california in a heavy populated area and those are the only 2 I have seen but they are factory equiped that way.
