Originally Posted by
ScarabEpic22
Just found your file from earlier in this thread, I see your truck is a 2000. Why not use an OS from 2002 like the popular 12212156? It should be more refined than the 2000 OS plus if you ever want to go to a COS its easy. Not sure you want to add another thing into the mix right now though!
Attached is a stock 02 12212156 OS file with a freshly copied 4L80E trans and trans diagnostic segment. I also put your VIN in, but didnt change any of the tables around. If it works for ya, great! The IFR is different between your tune and this one so I knew there would be a few things to move around. If you want to use it, open your old file and this new one and copy all the values from the 2000 tune to the 02 one.:rockon:
(BTW, are there any advantages to running say an OS from 03 vs 02 in a 512kb PCM? I know most people use the 12212156 OS because its great for Vortec swaps with the Express van tune, but what about regular trucks?)
