Send me your FlashScan serial and auth code as per these instructions
http://support.efilive.com/kb_articl...2143-YUOG-8049
and we'll replace the license.
Send them to [email protected]
Sent.
Thanks again!
So what do we do if a lb7 or lly controller doesn't recognize it has been licenced? First I have heard if this.
cummins 5.9 ECM.
parameter c1503 description reads "If the actual boost pressure remains below {C1504} "Low Boost Check Threshold" for this low a low boost DTC will set."
i believe it should read "If the actual boost pressure remains below {C1504} "Low Boost Check Threshold" for this long a low boost DTC will set."
That brings up a question? There's a lot of those descriptions I'd like to change, correct or at least reword. Any way too?
you can use the "User Comments" field to save your own notes againts the cal
English was not a subject I excelled at during school, nor does it help that typing those descriptions is really, really tedious work :music_whistling_1:
Don't want notes in the .tun file. Want them there in EFI Live so whenever I open a tune file I have all my notes!
