Thanks again...
Thanks again...
What I'm not understanding is the numbers are .7 to 1.2.....those are normal numbers? Then I copy with labels and paste and multiply....everything works as should?
But if I simply save the log and come back, the numbers are different (10s)....sometimes I cant copy and paste right away (log on my way to work 37 mile trip)
a log file and current tune file....
There is definitely something strange going on there. The EXT.AD1 voltage pid values are getting corrupted when you save the log. (I am sure your V2 would be dead if it saw 70 volts)
I would first try doing a complete reinstall of efilive.
OK, I'm gonna do this now.
Also let us know what build number of Efilive you are using.
Last time I down loaded the lastest version on this forum.
https://forum.efilive.com/showthread...pdate-Feb-2015
ok, i now have;
v8 8.2.2 build 270
7.5 7.5.7 build 276
boot 2.07.07 2/7/14
firmware 2.07.77
No worries. Now you will need to do another log, save & see if the EXTAD1 voltage still get corrupted. If it does we will have to kick it up the chain to get a fix.
OK...driving 40 minutes home , I'm going to log the trip....I'll report later.
