how do I disply the reading through the software?
You set up your V2 as per TAQuickness's tutorial (see earlier posts in this thread), then in the scantool you select and log the following pids:
WO2AFR1
WO2LAM1
WO2ST1
TA Q i sent you a pm about an fjo cable foe serial wb. do you have any cables made or are you going to make one? thx.
ArticSS - Sorry, but I do not currently support the FJO series of controllers.
ArticSS,
On your FJO, do you see a serial out port...? Can you post some pics...?
This needs to connect to the FlashScan serial port input.
You can make a cable: showthread.php?p=80530#post80530
Or you can get an adapter: see post #45 for an example -> showthread.php?p=80529#post80529
Your FJO serial connector will look different than the LC-1 shown in those links.
this is the controller i have.http://www.fjoracing.com/products/WB...%20rev%20C.pdf
i will try to get a pic this weekend.thanks joe
I've sustained a small data loss and cannot find my contact information for the guy looking for an LM-1/XD-1. If you see this, and you're that guy :), please send me a PM.
PM's replied. Thanks guys!
