The original post is good and has been updated for the most part. Different setups may need to be tweaked a little bit but you should be able to figure that out as you go. For example... I have LTFT disabled, so my closed loop histogram portion is based on STFT, not LTFT. I've also messed around and done it based on LTFT+STFT combined.
This is a great method for a MAF car because you can correct MAF and get a decent VE table in 1 log, without having to run open loop etc.
Nothing beats doing an AutoVE to really dial in the VE table with a wideband....but generally CalcVET is more than sufficient.
My car is speed density, but most of the time I still use the logic here to correct closed loop stuff with trims and WOT stuff with wideband. Again just to make it easier and more simple driving the car around like I normally would. You can tweak and combine methods as needed to suit your needs.
