done
done
Tuned all day with no problems!!!!!!!!!!!!!!!
Got it working, something about the auto update didn't work. Thanks Paul for the timely support.
I'm getting a Error 404 file not found so I did a manual install hoping maybe I was just a couple versions behind. Both manual installs where successful but still getting a error 404 when I try to check for new update. Search finds both files. I seem to remember this to be something easy but I can't remember what it is.
Also can you move the Check for update a couple lines away from Uninstall so I don't click on it by mistake?
For the benefit of all... We have disabled Auto Update presently due to an issue. Please download and install the full versions from our website. Also please ensure you update your FlashScan v2 device firmware. There is some more info in these knowledgebase articles that might help:
- Software updates: http://support.efilive.com/kb_articl...5404-IJZV-0820
- Firmware Updates: http://support.efilive.com/kb_articl...7243-SFGL-2949
The order of the items in the EFILive (and other program groups) is alphabetical. So we don't have much control over that sorry.
Regards,
HELP!!!!! since i have downloaded this update i tried to update the tune on a lly duramax and it locks the laptop up if i try to use V7.5 so i tried using V8 and when i did it erased the ecm just fine but when it gets to program it stops and give me an error that says no data received and starts the count down so now the truck is dead in the water does nothing at all when you hit the key lucky for me this is a friends truck so i let him borrow one of my trucks but this has got to be fixed NOW!
i can also be reached at torquedieselllc@gmail.com i really need a solution for this asap and i get email to that address on my cell phone
