iI found a weird problem which is two fold , first all software and pids for scanner are in imperial , but trying t do ve I have to switch map to metric for it to work and I tried this on several computers . second i have one computer that is correctly licensed for RR and efi and it stays in demo and the splitter doesn't work correctly scanner drops out about every two minutes , and im curious what else besides ve and or boost tables I can run and correct with RR , Joe we need a write up , a complete one I know Im new but I will help get it started ,maybe we can pull all of the good info of the threads and put those together and finish it , It would free you and others up alot to help with other issues
setting units to Metric in scantool:
- goto PIDs tab,
- click twice on column heading "Units" (sorts the pid list on that column),
- scroll down until you see a group of pids with units "kPa,PSI",
- highlight that group of pids (click on the first one, hold SHIFT, click on last one, release SHIFT),
- on the highlighted pids do rightclick->Metric (the Default column will now say Metric.
setting units to Metric in the scantool maps:
- choose a map (click the map's letter tab),
- goto the map properties,
- on each of the Data, Row and Column tabs select the Metric variant of the pid of interest,
- remember to checkmark "Show Units" on each tab,
- remember to save the map.
1 Attachment(s)
On PC where EFILive V7 software says Demo mode, go Help->Register EFILive copy the blue card details exactly (the date field is non-US style)...
also enter your RR serial number;
i.e. see attached:
Attachment 16947
Click Ok.
And then copy the file \My Documents\EFILive\V7.5\User Configuration\License.txt to all your PC's.
Are you using the old USB driver...?
Start->All Programs->EFILive->V8->EFILive USB Manager, and install 2.02.04.
so I should set the scan tool and the tune tool to all metric ? and yes the driver is updated , but why when im set to imperial everywhere do iz need to set map to metric ? its boggling my mind
It will be easiest to set everything to Metric.
In the map properties, an available pid will have two variants: Metric (e.g. SAE.MAP.kPa) and Imperial (SAE.MAP.psi)... choose the Metric variant.
