my os is 12216125 i take it that number has to match all the way though to work
I can't find that OS #. I'm going to assume that it is 12212156 in which case the correct custom OS for your stock OS is 020200xx series.Quote:
Originally Posted by 69camaro5speed
Apologies if this is not what you are asking.
From memory that O.S was used on the E85 Fuel trucks, we never did a custom O.S for that one. In the many months they have been out you are the only one that has ever asked!.Quote:
i looked again when i load the tune file it said os 12216125 cal.id 12216131 this is for a 2002 avalanch 8.1
:Eyecrazy: WOW lots of information to absorb. I have 00 WS6 and now I understand that I need the commercial version. No problem...I am ready to upgrade. I saw where the OS has different versions. Which OS year/version is the latest I can use and should I upgrade in small steps (ie. 00 to 01 to 02) or should I just jump from 00 to the latest and greatest...Yes I am I.T. guy too and have to have all the patches and SP's:exactly: Will the newer OS be easier to do the WBo2?
It was also mentioned that "EFI will have some very, very neat stuff in the final stages of testing right now that will make the commercial upgrade well worthwhile"... what is the "neat stuff" and should I wait a bit before upgrading??
I have also noticed that a lot of people like the dual spark map. Why is it better than single spark map?
On a side note what WB02 is best? I have been looking at the LC-1 and it looks good to me. Does the display from the cable readings display through the laptop or do I need a seperate display?
I would say you could probably update to the 2001 or 2002 OS used in the WS6. I'm not 100% on that though (we only have Holden's down here).Quote:
Originally Posted by ws6togo
There is very little difference (generally) between the 2001 and 2002 OS. I have checked several and they all have the same tables. I know exactly where you are coming from being an I.T guy, I am too :). These OS's are not like your PC OS's so don't try an compare them ;)
Tuning with a WB02 is easy in al OS's, there is nothing specific in the custom OS's that affect your ability to tune.
Neat stuff that I am aware of:
- Throttle position referenced fuelling
- Custom OS for NOS (N20)
Basically because it restores the ability to have adaptive spark maps while running speed density (MAFless). If running speed density on the stock OS's you only have the low octane map referenced.Quote:
The LC-1 is fine, a lot of guys use those cause they are a pretty good price. Basically what happens is that you wire the wideband output into the FlashScan unit and then log a PID that brings that data into EFILive (your laptop) logs.Quote:
Hope that helps a little...
Yes...thanks for the answers Tordne
ws6togo,Quote:
take one piece at a time, and "play" with the software alot;
read a tuturial and do a "dry run" first, understand all the steps;
when you're not sure about something, ask questions until it's clear;
there's a bunch of nice people here who are willing to help out...:rockon:
run the scan tool alot and check out as many PIDs as you can;
you'll do well, no worries mate.
Joe
:cheers:
Thanks, Its people like you, Black02SS, and others that make working with tuning cars a lot easier. I can see why more and more people are going to EFILive !!Quote:
Originally Posted by joecar
Just to clarify, if it's "MAFless" why do you still want to "run with a MAF", and as for "dual spark", that's 2 tables, not 2 flashes of the plug per compression stroke, correct? How does one select the alternate spark and the Rev limiter settings? Thanks!Quote:
Originally Posted by Tordne
