LC1 connections using NBO2 connector
Don't connect LC1-black to any ground; this is not a ground wire (see note 2 below).
It's best to not connect LC1-white or LC1-green to common ground...
connect either of them to the "return" of the measuring device (FlashScan-D or NBO2-A).
Don't connect FlashScan-D to common ground; connect it to LC1-white or LC1-green.
If you want NBO2 simulation, connect either LC1-yellow or LC1-brown to NBO2-B.
Don't connect NBO2-A to ground, even if it appears to already be "grounded".
Summary:
LC1-red -> NBO2-D
LC1-blu -> NBO2-C
LC1-yel -> NBO2-B
LC1-grn -> NBO2-A
LC1-brn -> FS-C or FC-E
LC1-wht -> FS-D and pushbutton/LED cathode(-)
LC1-blk -> pushbutton/LED anode(+)
Notes:
1. Note that LC1-white goes to 2 places.
2. Note that LC1-black drives the LED, and initiates calibration when shorted to ground (LC1-white).
3. Note that LC1-green and LC1-white can be interchanged and/or connected together,
and it's best to avoid connecting either of them to common ground.
4. If NBO2 heater power/ground is turned on/off by PCM, then you have to power the LC-1 by means other than NBO pins C, D... the reason for this is that the later PCM's manage NBO2 heater power via PWM.
