Re: Closed Loop SD and BEN Numbers
Quote:
Originally Posted by BowlingSS
Right now I am running Closed Loop SD. I am still logging my BEN and was wondering if I can still use these numbers just like I did when I was AutoTuning? Most of the numbers are around 1.0 but some are not as close probaly because I did not have enough data logged. I only logged about 3 hours of data and tried to hit every cell I could but some were hard to hit.
I was also thinking of just going to Open Loop all the time.
What does everyone think?
Bill
:D
You can definately do this, but I'm not sure what benifiet you would see. While you are in closed loop, the PCM is trimming the fuel based on O2 sensor feed back, so your WB reading will represent the AFR after trimming.
I would think you would get a better idea of what's going on by monitoring your LTFT's.
Re: Auto Tuning - Step-by-Step
Quote:
Originally Posted by TAQuickness
Here it is! A complete step-by-step write up for Autotuning
Revised 8.9.05 2355 (GMT-6)
Edit: for the time being, I cannot seem to make the add attatchment work. In fact, it's not even an option. So If you would like a copy of the doc, please email me.
If you would prefer an uncompressed copy of the document, please email me:
[email protected]
Do we email you for the 8.9.05 updated doc (I can't find the link to it)...?
