Got it fixed up. Just ran a 1 hour test of scanning w/bb. Thanks.
Cool... "I love it when a plan comes together..." :cheers:
After deleting codes, can you save the trace file and email it to me at [email protected]. The trace file option is in the scan tool options menu on FlashScan.
This is the file I used: http://download2.efilive.com/Softwar...ay_06_2008.zip
Jim
Exit from all EFILive software.
1. Run regedit
On XP click start->Run, enter regedit and click ok.
On Vista, click start, enter regedit into the search box (just above the start button) and click on the regedit link that appears.
2. Locate the key
\\HKEY_CURRENT_USER\Software\EFILive\V7\Properties \Dir
or
\\HKEY_CURRENT_USER\Software\EFILive\V7.5\Properti es\Dir
depending on whether you are running V7.4 or V7.5
3. Delete the Dir key and all its subkeys.
4. Restart the scan tool.
Deleting that key will clear all "known" EFILive folder locations. The next time EFILive is started it will figure out the correct folder names - assuming the software is installed correctly.
If that does not work, uninstall the software, delete the registry key:
\\HKEY_CURRENT_USER\Software\EFILive\V7.5 (or V7)
That will reset ALL EFILive's settings.
Note: uninstalling and re-installing the software does not reset the registry information. That is why I suggested doing it manually.
