Updated first post with international shipping rates. All PM's replied
Post Christmas pre New Year bump ;)
Listed new cable on first page :D
Im thinking of ordering an AEM 30-4100 - what cable will i need to use to log from it into Flashscan??
I don't know. If you have any documentation on the AEM serial interface you can email it to me and I'll let you know what I can do. [email protected]
I can bring it to work tomorrow and scan it.
In particular, I need specifics on the AEM serial output connector: type of plug and pin-out
Red - 12V
Black - Ground
White - 0-5V Analog output
Blue - Serial output
The connector is some goofy 4-pin connector, and I can measure the pitch when I get home. The ground would need to be split, and one would go to a ring terminal.
I was more interested in getting an adapter for the 4-pin square o2 sensor to the wideband analog output, and then just having 2 wires run down to the flashscan.
I sent an email with page 4 of the instructions.
You need to post a picture of the connector that
plugs into the beck of the AEM.
A part number will help as well.
It looks like it may be something that is not too common.
I noticed the AEM has only 1 wire for serial data, should`nt there be 2? (Tx Data & Rx Data)
RJ12___AEM___Data
1 <---> ???? = Tx Data
2 <---> Blue = Rx Data
5 <---> Black = Ground
I`m not sure about sharing the power ground with the RJ12 ground input.
LC-1 to BB pinout
I have attached the instructions with a picture of the connector. I can take a better picture when I get home.
