Well, It reads my Truck info and everything but the tune tool says the OS is not supported for it.
V7.5.7 (Build 235)
Email the file to [email protected] and mention that V7 says OS not supported...
also specify year/model/vehicle.
I email them already after I saw you comment. How long do they usually take to answer back?
Bump for 2013 Sonic OS #12655493...now I have one to tune!
Does anyone else have problems with the yellow monitoring button in V7 scan tool? I can't monitor PIDs. I have to use the red log button in order to see data. I've had this problem for the last few updates. It hasn't worked for probably 6-8 months.
Also, I guess the EDA PID list in V7 scan tool does not work??
Yellow button monitors data it does not record data. The charts show recorded data so you won't see any data on the charts while monitoring. The dash gauges should show data that is being monitored.
Why do you assume the EDA data does not work? What problems do you have with it?
I don't see any data at all on any gauges or charts. It seems like it starts to work for a split second then it pauses itself. When I click the paused button, it starts recording data.
When I select the EDA PID list, and hit record, the data screen locks up and you have to hit stop. Then if I select my normal PID list it works fine. Maybe I'm missing something. I'm good at that.
The yellow button is designed to do exactly that, start recording, but in pause mode so nothing gets recorded. In pause mde the data is displayed in the gauges and on the [Data (F9)] tab page but not in the charts.
EDA is for Cummins controllers that have been programmed with EFILive's custom operating system (that transmit the EDA data) only. IT won't work on any other controller or operating system.
